shifting problems
Old Jun 26, 2012 | 10:03 PM
rick king's Avatar
rick king
Default shifting problems
2001 5.9 Ram automatic trans shifts up an down,tac goes up to 3 grand and back down,having problems climbing hills,please help,Thank You Rick the truck goes up a gear an then back down a gear when climbing a hill over revving the engine. Thanks Rick Truck stays in lower gear sometimes an won't go into higher gear in over drive or drive ?
Old Jun 27, 2012 | 11:03 AM
Could you be a bit more clear in just what the issue is here?
Old Jun 27, 2012 | 11:33 AM
Sooper's Avatar
Sooper
Are you sure it's shifting, or maybe the overdrive is cycling on and off?
If it is falling down a gear and then back up you may have a failing pressure sender.
I just replaced my solenoid and sender with great results. From what I have read there are several problems and symptoms that stem from either or both failing.
Old Jun 27, 2012 | 05:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Blown plenum and clogged Gov solenoid.
