Broken vacuum line
Old Jun 30, 2012 | 01:18 PM
Mopar069's Avatar
Mopar069
Default Broken vacuum line
I was checking for a vacuum leak because of what I read for wild vents and found a broken vac line. It goes from a T on the right side of the motor through the fire wall with the A/C lines.
Any idea what its for and will it hurt anything running it the way it is for a few weeks. I will be replacing the dash, heater core and a/c evaporator at that time.
Old Jun 30, 2012 | 01:48 PM
If your vents still sorta work, that line probably goes to the vacuum reservoir under the plastic cowl piece at the back of the engine compartment. Just use a piece of rubber vacuum line to splice it back together.
Old Jun 30, 2012 | 09:21 PM
Mopar069's Avatar
Mopar069
I tried the vents and that is what the line is for. Now I only have defrost so I will be fixing that problem in a few weeks.
Thanks
