performance upgrades for a 360
Old Jul 6, 2012 | 07:58 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Not true.
Use Mopar Engine Conditioner or Sea Foam frequently. Replace the gasket with a metal one, not the former OEM fabric/cork type.
Doing everything else correct on the install, get new plenum bolts AND manifold-to-block bolts, and new gaskets for the manifold-to-block.
Old Jul 6, 2012 | 08:11 PM
Matt Nickerson's Avatar
Matt Nickerson
But....
In the plenum thread, the reason as to why the gasket fails is basically because of the two different metals expanding/contracting at different rates. Replacing with an aluminum plate would end that, no? And of course using a metal gasket in place of the cork one will help out.
Old Jul 6, 2012 | 08:14 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
That conclusion has never been proven and quite of few people have disagreed with that assumption. Ask yourself....when looking at a plenum gasket, which way is it going? Then ask yourself why?
Old Jul 6, 2012 | 08:19 PM
Adobedude's Avatar
Adobedude
Why use new intake manifold bolts when it's only 12 ft lbs?
I've reused the same button top SS bolts since 2004 through numerous intake changes.
If 12 ft lbs can stretch a bolt, it's made out of lead. How the bolts are torqued is the key.
Old Jul 6, 2012 | 08:32 PM
merc225hp's Avatar
merc225hp
Originally Posted by Wh1t3NuKle
Not true.
+1 on these posts,
Why would you not use new intake bolts they are like $7 for a set, they rust, they break off in the head, it would cost more in gas to go get them than what they are worth, so why not have them on hand when the job is started.
Old Jul 6, 2012 | 11:27 PM
Adobedude's Avatar
Adobedude
+1 on these posts,
Why not...? Not needed.
But Hey, AJ (Alan Johnson) could use the sponsorship money, so go for it.
Old Jul 7, 2012 | 12:13 AM
gdstock's Avatar
gdstock
And why spend too much money on a plenum plate....Get it HERE and you can use the saings to buy the gaskets or something else.
Old Jul 7, 2012 | 02:09 AM
haus84's Avatar
haus84
if they wern't so damn expensive i would just upgrade the intake and throttle body while i have it apart. also is a superchip tuner with 2 caned under $400 a decent price? if not where should i be looking
Old Jul 7, 2012 | 04:30 AM
Wombat Ranger's Avatar
Wombat Ranger
SCT is the tuner you want for max torque increase.
Wh1t3 - I just had a discussion with Sooper about the whole plenum thing in this thread. May shed a bit of light on the subject...
https://dodgeforum.com/forum/2nd-gen...ggestions.html
Also, good to see you posting here often again lately
Old Jul 7, 2012 | 09:05 AM
TGoodwin's Avatar
TGoodwin
And don't forget replacing the timing chain/gear set. That was the single biggest improvement on my truck.
Hmm. Timing set made a big difference? How many miles on it when you changed it?
