I thought that too... but for me it was up higher where the plastic meets the metal that I had a small crack. It began with a small leak, a few drops noticed in the drive each day when I got home from work (engine temp 195), then by the time I decided I needed to do something and gathered the parts, it was pissing enough to find the leak really easy.
I pulled the radiater out today and thats what was leaking, it was leaking from where the plastic meets the metal, it was also in the front thats why i could really see where it was leaking from!
So, what did you do or replace?...I'm asking because I'm having the same problem.
