Tires chopped
Old Jul 6, 2012 | 10:28 PM
Ramtruck97's Avatar
Ramtruck97
Yep bad shocks.
Old Jul 6, 2012 | 10:37 PM
SlingMudd's Avatar
SlingMudd
Consider doing your tires as well... or at least rotating them.... (unless all of them have the same wear...)
Yes I already planned on getting new tires should I do the tires first then shocks or shocks then tires also what brand shocks do you recommend thanks for all you guys help
Old Jul 6, 2012 | 10:44 PM
Do the shocks first. Have a look at the rest of your steering as well.... make sure everything is up to snuff. Tires are not cheap....
There is a thread in the faq section on shocks, might wanna have a read on that. I need to replace mine too..... (look original...) not sure what I am gonna go with.
Old Jul 10, 2012 | 12:44 PM
SlingMudd's Avatar
SlingMudd
If I am only getting about 1/4 to 1/8" play when I wiggle my tires back an fourth are the ball joints bad or is that normal thanks
Old Jul 10, 2012 | 01:21 PM
No play is normal. Shouldn't be any at all. Need to peek under there, and see what parts are actually moving, that shouldn't be.
Old Jul 10, 2012 | 02:34 PM
SlingMudd's Avatar
SlingMudd
So if there is movement it's doesn't mean it's the ball joint that's bad lol
Old Jul 10, 2012 | 02:44 PM
Depends on what is moving. From here.... I can't see squat. Need to poke about, and see what wiggles. Have someone else wiggle while you watch. (the truck, NOT the strip club....)
Old Jul 20, 2012 | 06:41 PM
SlingMudd's Avatar
SlingMudd
Does anyone know the torque spec for a 1500 4x4 front shocks are 200 thanks. Also any ideas on how to bust this bottom bolt loose on the shocks got all the other bolts loose expect for this **** this thing doesn't look like its ever came off and I have pb blasted that bitch too still no budge
Old Jul 20, 2012 | 07:35 PM
I think it's a bit over 100 pounds on the lowers.... aren't there rubber bushings on the top mount? You don't wanna crush those to nothing.....
May need to heat it. (acetylene torch.....)
Old Jul 20, 2012 | 08:04 PM
SlingMudd's Avatar
SlingMudd
Oh ok I didn't know about heating it lol
