1997 Ram/ Jasper trans. tcc issue
I have a 1997 ram that got a new jasper 46re hooked to the 5.9L bout 4 months ago and it started pulling a wire short error (oxygen sensor) now it is pulling a P0740 TCC No RPM drop at lockup. has any seen this code or know the best way to fix it since its a daily driver.
Have you called the place that installed the trans? I would assume you have a warranty on it.
Having said that, I wouldn't own a Jasper product. I made that mistake about 10 years ago. I had a 96 Dodge Intrepid, and went through three transmissions before I junked the car. The stock trans puked, and both Jaspers I had installed. The second Jasper was free, as it was covered by the warranty on the first one, but I still had to pay to have it swapped. That sucked the big one.
@Josh_Putman. Idk if jasper covers it being a stock dodge converter. My Dad installed mine a year after he put his in his cummins.
@QuadCabLuv I know for a fact that the Cat was changed 4 years ago. It actually might be that gasket but motor runs smooth the Solus reader I was using said upstream wire shorted. I do know Dad bumped it when we put the transmission and hooked the exhaust back up (Dodge Cat wasn't put on, this one is GM)
So you had a new/rebuilt tranny installed with the old converter ?
