DO I really need Mopar lube in Tranny??
Old Nov 25, 2005 | 01:29 PM
New_Climber's Avatar
New_Climber
Default DO I really need Mopar lube in Tranny??
I have a 94 ram 1500 and I am wanting to change the tranny (NV3500 5-speed) and transfercase fluid (NP-231). All my research has said I need the purchase the Mopar manual transmission lubricant P/N 4761526 (ONLY) due to the "yellow metal" synro...is this really necessary or can I just use a 80-90w syn gear oil?? Thx greatly for the help
Old Nov 25, 2005 | 03:09 PM
V10's Avatar
V10
Default RE: DO I really need Mopar lube in Tranny??
You can use either the Mopar or GM stuff or 5W-30 synthetic motor oil, but don't use 80-90 gear lube in the 3500. The EP additive in gear lube etches yellow metals like brass or bronze.
Old Nov 25, 2005 | 04:09 PM
The Burning Rom's Avatar
The Burning Rom
Mopar Manual Transmission Lubricant (PN 4761525) is the ONLY lubricant recommended for the NV3500.
Straight from www.dodgeram.org
Old Nov 28, 2005 | 05:53 PM
Aaronon38s's Avatar
Aaronon38s
I put amsoil 80-90W oil in my tranny after a complete rebuild. But 1000 miles later, the bearings burnt up and I had to rebuild it all again. You don't want to know how much it costs. DO NOT use gear oil (axle oil) in your transmission. Just my $.02
Old Apr 6, 2006 | 01:30 AM
whitedog's Avatar
whitedog
Thankfully this site has a nice search feature. Looks like I need 2 quarts of the Mopar oil and one quart of Mopar DexII?
Old Apr 6, 2006 | 03:49 PM
dodge_boy31807's Avatar
dodge_boy31807
The guy that I bought my tranny from owns a shop and he told me to use 5w-30 motor oil in it, said that it is the same thing and works just as well. The only reason to buy that mopar stuff is for your money. Before my tranny went out I put 80w-90 synthetic mobil 1 in it, and that stuff cost $10.00 a quart. Plus my tranny is under warrenty still and if it burns up on that motor oil then so be it but that is what he had told me to use and said it works fine. I haven't had any problems with it.
Old Apr 6, 2006 | 04:20 PM
The Burning Rom
ORIGINAL: dodge_boy31807
This thread was inquring as to what to use in a MANUAL transmission As I posed way back when, you shouldn't be using anything but the Mopar lube. You run the risk of ruining your transmission if you do.
For an automatic, you can run synthetics from Mobil or Amsoil though. I wouldn't run motor oil in it. [>:] That worked for the old 727s and transfer cases that had cast steel housings...but it's not a good idea for the newer transmissions/t-cases with the aluminum housings.
Old Apr 6, 2006 | 08:32 PM
Ram_Sport's Avatar
Ram_Sport
my tranny just told me, "leave me alone im fine" i was like w/e jackass...
[sm=smarty.gif]
Old Apr 7, 2006 | 01:25 PM
dodge_boy31807
My truck has a manual tranny in it and the guys from the shop where i bought the tranny told me to run 5w-30 through the tranny. I know that this forum is about manual otherwise i wouldn't have posted on it lol.
Old Apr 7, 2006 | 02:53 PM
GOD RAM IT's Avatar
GOD RAM IT
I WOULDNT PUT ANYTHING OTHER THAN WHAT DODGE RECOMENDS!
46RH = ATF +3
46RE = ATF +3 or +4 depending on the year of the truck. If your tranny has ATF +3 than you can upgrade to ATF+4 but you cant go from ATF +4 to +3. JUST an FYI ATF +4 is dealer only oil and costs 16-20 a gallon. ouch!
Manual trannys = Mopar tranny lube
