exhaust and tranny
Old Jul 9, 2012 | 10:10 PM
haus84's Avatar
haus84
Default exhaust and tranny
98 ram 2500, can i cut out the cat without throwing o2 codes or does anyone know of any dummy plugs i could plug the 2nd o2 sensor into to keep it from throwing them. also with the nv4500 would it be safe to pull a 4000 lb trailer in 5th or should i keep it to 4th when towing?
Old Jul 9, 2012 | 10:38 PM
gdstock's Avatar
gdstock
Yes you can cut out cat, and yes it will throw codes. Do a search for "O2 sensor trick" which uses spark plug anti-fouler and this may take care of it.
Welcome to DF.
Old Jul 9, 2012 | 11:43 PM
haus84's Avatar
haus84
thanks i'll give it a shot once i convince the local exhaust shop to cut it out
Old Jul 10, 2012 | 08:10 AM
ben h's Avatar
ben h
good luck on getting them to do that unless they do it off the books cuz its around a 25000$ fine for them if they get caut
Old Jul 10, 2012 | 09:32 AM
Ham Bone's Avatar
Ham Bone
You can gut your own cat with a hammer and a pry bar
Old Jul 11, 2012 | 02:13 PM
haus84's Avatar
haus84
the only reason they told me that they would not be able to do it is if there is an o2 sensor behind the cat, because it would throw a code. small town usa the local ford dealer is the place to go for dpf and egr deletes
Old Jul 11, 2012 | 02:17 PM
dlyter09's Avatar
dlyter09
Are they charging you for this?
Old Jul 11, 2012 | 05:37 PM
Wombat Ranger's Avatar
Wombat Ranger
...with the nv4500 would it be safe to pull a 4000 lb trailer in 5th or should i keep it to 4th when towing?
Yes. Our 360s couldn't hurt that transmission if they wanted to. As long as you are geared for pulling in OD like that you won't hurt anything.
Old Jul 12, 2012 | 09:35 AM
haus84's Avatar
haus84
@dly, yeah they charge about $50-$75 depending on what they have to do to get the cat out and pipe and weld back in
@2x, it has 4.10 gear in it and i do alot of towing on the interstate, unfortunatly we have some decent hills out here so it isn't just a nice cruise
Old Jul 12, 2012 | 10:47 AM
Wombat Ranger
Nothin' like the west side of MT though
Keep oil in that tranny (don't ask...) and it will last forever behind that 360. It's a diesel trans so it doesn't even notice our little v8's in front of them. I love mine.
