'01 5.9 missfiring help needed
Old Jul 12, 2012 | 08:41 PM
My360's Avatar
My360
Default '01 5.9 missfiring help needed
When I bought the truck, cylinder 4 and 6 were miss firing. Changed the coil, cap, rotor, plugs and wires. It ran perfectly for almost 2 months. Just last week cylinder 4 began to miss fire. I checked the plug and it was looking ok but, changed it anyways. Didn't help so i switched cylinder 4 with 6 to see if i had a bad wire.... then 6 popped up. Got a new wire cleared the code... now both 4 and six are showing. didn't do the trick. Anyone got any ideas? There isn;t really any lack of power except once when I gunned it to pass a car, it kind of jerked and didn't really want to go. Hasn't done that again though. Any help is greatly appreciated.
Old Jul 12, 2012 | 08:56 PM
stewie01's Avatar
stewie01
What kind of plugs are you using?
Old Jul 12, 2012 | 10:36 PM
dhvaughan's Avatar
dhvaughan
have you fixed your plenum yet ?
Old Jul 13, 2012 | 09:31 AM
My360's Avatar
My360
I put in the Champion copper plug's and I haven't been having any problems with the plenum yet.
Old Jul 13, 2012 | 10:13 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
#1) Have the cat pressure tested
#2) Verify the plug wires are properly routed per the TSB
Old Jul 14, 2012 | 11:00 AM
My360's Avatar
My360
Already re-routed the plug wires. As for pressure, I go do that today. I have to change the A/C compressor clutch and the idler pulley. May as well check the cat while I'm at it.
Speaking of that. I was planning on either gutting the cat or just taking it out all together. Once i do that, I'll have to move the two sensor's in front of the cat, right?
