power steering pump still leaking
Old Jul 16, 2012 | 04:32 PM
  #21
Well, get your truck back, find out what brand pump they were putting on, and then DON'T buy that brand pump....... Do the work yourself, flush the gear box before sticking the return line back on the pump........ make sure the fluid runs out of there CLEAN before closing it all back up. Also make sure that it isn't something stupid like a nicked o-ring, or some such.
Old Jul 16, 2012 | 05:01 PM
  #22
cutthroatxxx's Avatar
cutthroatxxx
soon as they put the old one back on Im gonna go buy a new one from the dealership...the ones they put on are remand from napa...have you ever heard of a gearing box causing the ps pump to go bad?I didn't see nothing in the pump..I will flush.
Old Jul 16, 2012 | 05:31 PM
  #23
I haven't even seen a steering gear box fail.... ever.... sloppier than a two-bit hooker, yeah, but, completely fail? Nope.
Old Jul 16, 2012 | 06:01 PM
  #24
Sooper's Avatar
Sooper
My thoughts exactly. These gear boxes are on the tough side even when pushed, and when pushed really hard, they just wear faster. Not seen one failed.
Old Jul 16, 2012 | 06:17 PM
  #25
Matt Nickerson's Avatar
Matt Nickerson
If you end up looking to get a new box, why not get the newer Delphi style aka the Borgeson Dodge Box? Not sure how much a replacement from the dealer is but, DodgeOffroad has the box for like $375 I think. When my PS stop leak stops working I'll probably buy the Borgeson box & shaft.
Old Jul 16, 2012 | 10:38 PM
  #26
gdstock's Avatar
gdstock
The pump is the least complex component of the power steering system (other hthan hoses). And pumps are rated higher (pressure) than the devices they drive. I also have never heard of any steering gearbox fail to a point where they adversely effect a pump. The guys at that shop are just not real good...rtechnically or customer servvice wise, either one. You know they can get the part exchanged from their supplier!
I have installed a rebuilt pump from autozone on several vehicles overe a number of years....and never had a problem with them. I always get theo one with the lifetime warranty and not the cheapest one they have. My Ram has one on it at this time.
And +1 on flushing it out. Gearbox has a small oil capacity so it should not take much - just do not run the pump dry...and it will be messy....
If your gerabox is too sloppy, the Borgenson or Red Head are the way to go. But the Borgeson will not connect directly to your steering shaft...or so I read....without modifyuing or changing shaft.
Old Jul 17, 2012 | 12:43 AM
  #27
Matt Nickerson
All you have to do to make the stock shaft fit to the borgeson is to grind down a little area on the box where the shaft connects. I also heard there is an adapter to make it fit instead of grinding it down, but haven't searched it yet.
Old Jul 17, 2012 | 05:12 PM
  #28
cutthroatxxx
ok so these guys said yesterday they were gonna track down my old pump&put it on&give me my money back &today they said they couldn't find my old pump&put a new one on&that it started making noise the same as the last one&there not gonna refund my money err said your gear box is eating em up.I'm pissed.
Old Jul 17, 2012 | 05:19 PM
  #29
Sooper's Avatar
Sooper
How much have you paid them so far?
Old Jul 17, 2012 | 05:21 PM
  #30
cutthroatxxx
245 buck
