1997 dodge ram trans question
Old Jul 16, 2012 | 12:22 AM
ff743's Avatar
ff743
Default 1997 dodge ram trans question
ok here we go i have a 1997 dodge ram 2500 5.9 gas automatic
when it would warm up it would stop pulling after it cooled down it would go again
so i got another tranny from a running truck drove it myself put it in and now i have the same problem with it
fluid level is good in neutral not burned this was a perfectly good working tranny
any ideas before i scrap it dont want to buy a new one if i am just going to have the same problem with it also the trans temp lite came on once no blockage in any of the lines or the cooler
Old Jul 16, 2012 | 09:00 AM
Did it do the same behavior immediately after being installed? Or, did it work ok for some time first?
Old Jul 16, 2012 | 11:29 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Original torque convertor?
Old Jul 16, 2012 | 04:58 PM
ff743's Avatar
ff743
yes it worked fine for probably 50 miles then it started now it will only pull for probably 30 seconds or so. bypassed all coolers thinkin it may be blocked still does the same thing
the guy said he put a jasper in it a few years ago it did have the painted torque converter
Old Jul 16, 2012 | 05:00 PM
ff743's Avatar
ff743
Old Jul 16, 2012 | 11:23 PM
ff743's Avatar
ff743
i put a clear line on so i could see what was going on.
i can leave it in neutral and there is no fluid flowing and after a few min i hear a like chatter noise and then the fluid flows for a little bit and then it stops again after a few min it will flow again someone said torque converter was bad any ideas i would order a new tranny but i am afraid i will have the same problem
Old Jul 16, 2012 | 11:31 PM
gdstock's Avatar
gdstock
Reusing a converter from a failed transmission can cause a good transmission to go bad. The reason? trash and debris from shelled out tranny goes into converter,,and when reused, this ttrash goes into treplacement transmission.
Pull the pan and the sensor and solenoids. Look for trash around magnet and on those parts.
Old Jul 17, 2012 | 12:15 AM
ff743's Avatar
ff743
i didnt use the one from the bad one i used the one that was in the truck i pulled the tranny from
Old Jul 18, 2012 | 06:15 PM
ff743's Avatar
ff743
does anyone at all know what this may be if it is just a converter then i can change it but i am at a loss heeeeeeeelp
