96 hesitates and runs poorly
Old Jul 16, 2012 | 11:46 AM
trent718's Avatar
trent718
Default 96 hesitates and runs poorly
i got a 1996 1500 360 and it runs rough after sitting a while till it warms up. once it hits normal temp it runs perfect but until it gets there it fights me i cant even drive it till it warms up the idle will surge up and then down and sometimes die. i am lost have done cao rotor plugs wires distributor cam and crank sensor plenum iac valve. the cat is gutted also
Old Jul 16, 2012 | 01:26 PM
Check fuel pressure.
Old Jul 18, 2012 | 03:51 PM
trent718's Avatar
trent718
i put a new fuel pump in it to i forgot to tell you that
Old Jul 18, 2012 | 05:20 PM
Lemunman's Avatar
Lemunman
Gutted cat owner here and o2 sensor gave me hell..My guess it has something to do with your fuel as what hey you mentioned
Old Jul 18, 2012 | 10:16 PM
What brand, and how long ago?
On the first startup of the day, will it run ok for a minute or two, and then starting doing strange things, or, does it do strange things right away?
Old Jul 18, 2012 | 11:35 PM
gdstock's Avatar
gdstock
Still check fuel pressure...new pump or not....
What brand pump? Any problems installing it?
What made you change it?
Old Jul 19, 2012 | 12:07 PM
trent718's Avatar
trent718
i forget the brand i had no trouble putting it in. it does it the first start up unless it cools down all the way. it just fights while it is trying to warm up
Old Jul 19, 2012 | 12:15 PM
Still, I would verify fuel pressure at start up..... see what ya get.
What about O2 sensors? How old?
