Could this be my A/C problem... 2000 Ram
Old Jul 21, 2012 | 08:24 PM
Mopar069's Avatar
Mopar069
Default Could this be my A/C problem... 2000 Ram
A/C hasn't worked for yrs and while I was replacing my dash today I saw what I think is some sort of actuator. It has a vacuum line on the bottom and should be attached to I think the recirculation door. I have a picture but can't figure out how to post it.
Old Jul 21, 2012 | 11:04 PM
Upload your pic to one of the photo hosting sites. (you will have to create an account there..) Imageshack, or photobucket work fine.
Once you have the image uploaded, if you mouse over it, it will bring up another little blurb below it, click on the spot for "image code" that will copy the code you your clipboard, then, you can just right click, and hit "paste" to post the image here.
Recirc door won't prevent the A/C from working. Does the compressor run at all?
Old Jul 22, 2012 | 02:07 PM
ReadRam's Avatar
ReadRam
Check fuses and a/c relay out under hood. Horn fuse is linked with a/c request. Lot of possibilities left after that.
Old Jul 23, 2012 | 02:26 PM
Mopar069's Avatar
Mopar069
Lets see if this works..
fuses are good and I will be checking the relay. Thanks
Old Jul 23, 2012 | 04:41 PM
Mopar069's Avatar
Mopar069
I see that the picture did post, just a little big. guess that didn't work
Old Jul 23, 2012 | 06:22 PM
I suspect that bracket is supposed to be bolted to that door there.....
