Plenum kit didn't fix my problem!!
Old Jul 22, 2012 | 01:34 PM
ReadRam's Avatar
ReadRam
Look at replacing cat or eliminating it, probably clogged if needed plenum fix. 2nd or 3rd on the 02 sensor and cleaning or replacing IAC.
Surprisingly, replacing ignition coil and finally using a brass terminal dist cap on my last tune up got rid of persistent pinging when accelerating.
Old Jul 22, 2012 | 01:41 PM
redneck_ram's Avatar
redneck_ram
he stated in a earlier post that the cat had already been removed.
+1 on brass terminal cap & rotor!
Old Jul 22, 2012 | 05:18 PM
sgtduckkiller's Avatar
sgtduckkiller
Ok, here is an update for ya. This morning I removed the front O2 sensor and there was no change, other than the exhaust leak. I also pulled out the TB, replaced the gasket and cleaned the IAC. That fixed the idle problem i think (it runs around 800-900 rpm). So now I'm back to the original problem. I removed all plugs and the all looked good, I replaced them 1500 miles ago. Also all the plug wires looked good. The only thing I have not looked at is the distributor cap. I was just tired of being in the super man position. I have new wires and a distributor cap and rotor sitting in the truck waitin to be thrown in. I hope that fixes it, I don't wana have to buy a tuner just to fix it but it would be a good excuse to tell the wife lol. I plan on doing that stuff after work if it isnt to late.
gdstock, I'm currently in trng. at Sheppard AFB. I will be PCSing to Little Rock AFB in a few weeks, that's why I need this dang thing fixed.
Old Jul 22, 2012 | 05:32 PM
Grolli's Avatar
Grolli
aack.. Sheppard.. wow.. spent time there myself. Good luck, had similar problems and the cap and rotor fixed it up nice.
CE?
