please help!!!!!
Old Jul 25, 2012 | 12:48 AM
  #21
vaninator's Avatar
vaninator
Originally Posted by S S0DEN
I would start small first, while replacing the plug wires, grab a flash light and look in the TB, look for standing oil in the bottom of the intake. This usually points to a bad plenum gasket or a really bad PCV valve.
If you find a blown plenum gasket, you may also have a clogged cat as the oil is sent through the engine and absorbed by the mesh in the cat.
This can cause a serious issue with power ect.
To check the cat, pull the forward (upstream) O2, start the engine and see if the engine seems more powerful. That little bit goes a long way if the cat is clogged...
Where is the upstream o2? And will A regular wrench work? If so, what size? If not, what tool would I need?
Old Jul 25, 2012 | 12:50 AM
  #22
vaninator's Avatar
vaninator
Sounds like a bad IAC, if you already replaced it and it's still doing it - it could be the sending unit or something down the line that's telling the IAC to open when it should be closed.
Should I try the iac again? I did NOT reset pcm when I tried to see if that was the problem
Old Jul 25, 2012 | 12:53 AM
  #23
vaninator's Avatar
vaninator
Also, where is the sending unit?
Old Jul 25, 2012 | 01:33 AM
  #24
tbone360's Avatar
tbone360
I didn't replace cap and rotor, just plugs. Should I start with that for fuel economy? And if it is my plenum gasket, how long does it take to replace?
If replacing the plenum plan on spending a day or 2 not all that hard tho it depends on your skill level. Seems like tou take more time cleaning. You want all thoes parts put back together squeaky clean.
Old Jul 25, 2012 | 08:13 AM
  #25
Mine took four days..... That was mostly scheduling issues, and an empty oxygen tank though...
Book says around 6 hours. But, that is for an experienced mechanic. Give yourself the weekend to take care of it.
Old Jul 25, 2012 | 10:16 AM
  #26
S S0DEN's Avatar
S S0DEN
1) Upstream 02 is the one in the cat or just before the cat on the engine side.
2) Yes, if you have it, replace it and unplug the battery for 15 minutes.
3) The PCM will store codes and driving conditions until you force the reset.
Old Jul 25, 2012 | 12:16 PM
  #27
fromthisdesk's Avatar
fromthisdesk
Default Coil
Check the coil - my '95 was sluggish and idling a little rough. The coil change-out fixed my problem.
Old Jul 25, 2012 | 05:02 PM
  #28
vaninator's Avatar
vaninator
Could it really be something as simple as that? And what was your truck idling at? Also, could that cause poor fuel economy?
Old Jul 26, 2012 | 09:09 PM
  #29
ReadRam's Avatar
ReadRam
Maybe finish doing basic tune up. Replace dist cap (brass terminals) and rotor. Plug wires and route them per TSB. Go for new coil while your at it. First things first. Then see where your at.
Old Jul 26, 2012 | 11:18 PM
  #30
vaninator's Avatar
vaninator
looked at plenum.. very very little oil it really just looked like burnt oil. I will try distributor cap and wires when I get paid on the 31st.
Posted from Dodgeforum.com App for Android
