tranny issues 01 ram 1500
Old Jul 25, 2012 | 01:47 AM
moparnocar's Avatar
moparnocar
Angry tranny issues 01 ram 1500
hey guys I have an 01 ram 4x4 wit 46re transmission its a good truck but i had the tranny rebuilt and it was working great but now its stuck in 1st gear and wont shift at all its throwing codes for th o.d./tcc and the govner im lost with this one if any one can please i I love this truck and have alot invested in it
Old Jul 25, 2012 | 01:53 AM
moparnocar's Avatar
moparnocar
Angry trouble starting
it also has a problems starting once in awhile what i meaqn is you turn the key and nothing happens not even a click please help thank you
Old Jul 25, 2012 | 08:12 AM
Two suggestions, first, check the 8-pin connector on the drivers side of the trans, half a foot or so behind the shift linkage.
It that ain't it, take it back to where you had it rebuilt.
Old Jul 25, 2012 | 11:10 PM
moparnocar's Avatar
moparnocar
i have no way of taking it back to the guy that rebuilt it he was a friend of my uncle and he passed away. im just trying for any suggestions thank
Old Jul 25, 2012 | 11:29 PM
gdstock's Avatar
gdstock
OK. That makes it a little more difficult. Check the connector as HeyYou stated, This connector supplies power to the governor solenoid, TC lockup and OD solenoids. It also provides for pressure sensor to send signal to PCM on fluid pressure, and without that reading, it will not know to shift up.
Let us know what you find out. Also, check fluid level - and do it in Neutral and not in Park. (only use ATF+4!)
And I did not look to see if you are new here, but if so, go to FAQ/DIY section and download the 01 service manual. It has a great trans section in it with diagnostics and other data. Grab the parts manual also.
There are also a number of tranny threads here about rebuild and other problems and solutions. Let us know what you find and we should be able to help get you shifting!
