2001 dodge head lights being dim
Old Jul 25, 2012 | 10:29 PM
leewatkins's Avatar
leewatkins
Default 2001 dodge head lights being dim
i have a 2001 dodge 3500.. the stock head lights were so dim i couldnt see the road let alone 10 feet in front.. so i change them out to after market recon lights, and changed the bulbs to the brightest lights on the market for this truck.. but still on dim i cant literally see the light leaving the front of the truck while driving. i have to have the bright lights on.. what can i do to make the dim lights acually be seen by me without leaving my bright lights on? i hope someone else has had this problem before.. im out of ideas... Leewatkins
Old Jul 25, 2012 | 10:39 PM
dhvaughan's Avatar
dhvaughan
are the lenses cloudy? either clean with kit or rubbing compound or replace lights.
consider a new headlight harness from LMC that adds a relay and power wire to the battery. i haven't used it but some have with mixed opinions.
this won't help you on dim, but i use a brite-box which turns on both low and high when on brites. excellent product !!!
Old Jul 25, 2012 | 10:40 PM
crazzywolfie's Avatar
crazzywolfie
maybe you could put the low beams on replays. from what i see it looks like the high beams are on relays but for some reason the low beams are not. i guess dodge cheaped out.
Old Jul 25, 2012 | 10:46 PM
leewatkins's Avatar
leewatkins
well i think yall are on to something.. i have brand new head lights on now.. i thought it would have been that the lenses were yellowed but i just changed the whole thing out. ill go to lmc and check te harness stuff out.. i hope i can fix it cause its not fun with these lights.. cant even see the deer..
Old Jul 25, 2012 | 10:54 PM
crazzywolfie
it is amazing what a faction of a volt will do to increasing the amount of light being put out by a light. i think most new vehicles have stuff like lights installed on relays for that reason. i know i am planning on putting all my headlights on relays eventually. just got to stop being so lazy.
Old Jul 25, 2012 | 10:57 PM
dhvaughan's Avatar
dhvaughan
here's the LMC link.
http://www.lmctruck.com/icatalog/de/full.aspx?Page=61
by the way, i tried the silverstar ultra bulbs and wasn't impressed.
after one burned out i replaced them with a Phillips brand which i thought was brighter and they were cheaper.
Old Jul 26, 2012 | 03:50 PM
leewatkins's Avatar
leewatkins
hey thank yall. ill sure try the new way of wiring up. and the different bulbs.. yall giving me some different ways of thinking about those lights.. i knew they have to be brighter than that.. heck most cars on thier dims are brighter than me on brights
Old Jul 26, 2012 | 04:10 PM
gertie240's Avatar
gertie240
Thats not a bad price from LMC. There is a really nice write up in the DIY section about making them yourself.
I called LMC one time to ask them about the wire size but they couldnt tell me. When I get motorvated I am going to rewire mine. I went to a junkyard and got a fuse panel from a Jeep full of relays and fuses for my platform.
Old Jul 26, 2012 | 04:21 PM
gertie240's Avatar
gertie240
Old Jul 26, 2012 | 04:44 PM
crazzywolfie
so were you going to use the PDC under the hood or where you just going to use the relays? only reason i ask is i think it would get a bit busy under the hood if you where to install another PDC. now if you where to have older trucks like mine then it would be a great upgrade.
