bent pushrod
Old Jul 29, 2012 | 07:45 AM
jacksdak's Avatar
jacksdak
I broke a valve spring and bent a push rod in my 5.9 R/T.It didn't hurt anything other than the push rod.I was about 5 miles from my brothers shop when it broke so I drove it there missing and making lots of noise.After 1 of the stock springs broke I replaced all of them with the MP.525 springs.
Old Jul 29, 2012 | 06:03 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by boxer15
so, when they go to change the spring they will have to use compressed air to hold up the valve anyway and if the valve is damaged it will leak air, correct?
also, would a dropped intake valve or dropped exhaust valve cause raw fuel to get dumped into the cat?
they might use air, they might use rope to hold the valve up.
if the valve or seat is damaged, it might leak.
you'll want to do a compression test afterwards to know what your engine status is.
bent push rod will cause the valve not to open.
broken valve spring "might" cause it not to close up.
if intake valve is working and drawing in fuel, and exhaust valve is staying open it will allow the fuel to escape on the compression stroke and yes it does flow into the exhaust, cat, muffler.
lots of unknowns. i wouldn't try to overthink it. just fix the 2 known problems and see if it'll run right.
