'95 V10 2500 Ram - How di I turn off the "MAINT REQD" light?
Old Jul 29, 2012 | 07:23 PM
IGot2P's Avatar
IGot2P
Default '95 V10 2500 Ram - How di I turn off the "MAINT REQD" light?
The title basically says it all. I have too many trucks so was preparing to sell the old 1995 2500 V10. Washed it all up, wife vacuumed and cleaned the inside, I recharged the air conditioner, and then took it for a drive. As you might have guessed, during the drive it went over 120,000 miles and my "MAINT REQD" light came one.:-(
Well, it obviously needs to be shut off before I can sell it and it does not appear that the truck is even OBD II compliant so I am lost. Any suggestions short of going to a Dodge dealer would be greatly appreciated.
Don
Old Jul 29, 2012 | 07:34 PM
dlyter09's Avatar
dlyter09
Disconnect the battery and leave it off for a while. Then reconnect and it should be gone. Where are you from?
Old Jul 29, 2012 | 07:50 PM
IGot2P's Avatar
IGot2P
Extreme SE Iowa.
Don
Old Jul 29, 2012 | 09:18 PM
IGot2P's Avatar
IGot2P
Cable was disconnected for over an hour....no joy, light still on.
Don
Old Jul 29, 2012 | 09:27 PM
QuadCabLuv's Avatar
QuadCabLuv
There is a trick i have heard of that requires you to turn the key and press the brake pedal in a certain sequence. I cant remember it right now but hopefully someone else will chime in.
Old Jul 29, 2012 | 09:37 PM
Did a bit of research here, seems the common consensus is.... you need a scan tool to do it. Most decent shops should have one....
Old Jul 29, 2012 | 10:06 PM
IGot2P's Avatar
IGot2P
Yeah, unfortunately my research came up with the same answer. Just thought maybe someone had stumbled onto a clever work-around. Thanks for the effort.
Don
Old Jul 29, 2012 | 10:25 PM
QuadCabLuv's Avatar
QuadCabLuv
i bet autozone could clear that for free. its worth a shot.
Old Jul 29, 2012 | 10:44 PM
IGot2P's Avatar
IGot2P
I called both Autozone and O'Reilly's this afternoon without any success. In short, I tried two shots but both were misfires.
Don
Old Jul 29, 2012 | 10:52 PM
stewie01's Avatar
stewie01
I haven't yet seen a Auto Parts Store with an OBDI Scanner. Probably gonna have to take it to a regular shop....
