want to lift my truck!
Old Aug 2, 2012 | 01:45 PM
99 Dodge Ram's Avatar
99 Dodge Ram
Default want to lift my truck!
i need a little help im getting a 2 inch body lift and a 3 inch suspension lift, i have a 99 dodge ram with 145000 on it bone stock 4x4 auto, this is going to be uses mostly as a daily driver but might see a few trails but nothing bad was wondering if i need to get longer brake lines and drive shaft and if theres anything else needed? (what im planing to buy are in the links)
https://www.topguncustomz.com/p-7063...-lift-kit.aspx
https://www.topguncustomz.com/p-7994...f-country.aspx
Old Aug 2, 2012 | 01:49 PM
merc225hp's Avatar
merc225hp
Welcome to DF
No and No
There is a needed bumper bracket set for the body lift.
Old Aug 2, 2012 | 01:57 PM
99 Dodge Ram
thanks for the quick response and alright
Old Aug 2, 2012 | 02:06 PM
merc225hp's Avatar
merc225hp
So five inch lift that would indicate 35" tires are planned, start looking for 4.56 gears sets. To help a little more and remove the death flash look at getting a SCT tuner.
Old Aug 2, 2012 | 02:19 PM
mantisman51's Avatar
mantisman51
Wouldn't the steering have to be adjusted for a lift that high? These ball joints aren't the toughest on the planet to start with.
Old Aug 2, 2012 | 02:35 PM
merc225hp's Avatar
merc225hp
An alignment after the lift is a given, after three inches of suspension lift then things get interesting and expensive.
Old Aug 2, 2012 | 02:43 PM
Matt Nickerson's Avatar
Matt Nickerson
FYI that kit does not come with any 3" lift shocks even though they're pictured...
You're paying $400 for coil spacers (not coil springs), AALs, and control arms and a track bar bracket that you don't need. You could buy $80 3" lift spacers, maybe a 1" AAL for another $80 and then spend $120 or so on shocks. Much cheaper that way, but it's up to you...
And as merc said, if you're gonna run 35" tires you'll need to get 4.56 gears.
Old Aug 2, 2012 | 02:47 PM
malrick's Avatar
malrick
could just buy 1 ton coil springs to lift the front and blocks for the rear.
Old Aug 2, 2012 | 02:54 PM
merc225hp's Avatar
merc225hp
Be it little he does need the track bar bracket, it's only 3/4" but it is needed if he likes his tires. The lower control arms are also needed they are 3/4" longer than stock.
Edit: Unless you know exactly what parts you need to lift a truck "right" buy a kit and a good one.
