231HD Transfer case tick..
Old Aug 2, 2012 | 10:17 PM
Purple5gear1500's Avatar
Purple5gear1500
Default 231HD Transfer case tick..
My 98 Ram has a tick in the T-case only when engaged. In 2H there's no noise.. In 4H there is. Haven't tried 4L as I don't use it much. But any how. Can anyone tell me what it could be. I have heard the Drive chain gets stretched. If it is the chain how hard is it to do?
Old Aug 2, 2012 | 10:19 PM
gdstock's Avatar
gdstock
Search for T case saver thread...and check yours. Mine is 2wd, so I don't know any more than I have read on here....
Old Aug 2, 2012 | 10:42 PM
Matt Nickerson's Avatar
Matt Nickerson
Checking the fluid in it couldn't hurt...
Old Aug 3, 2012 | 07:23 AM
dhvaughan's Avatar
dhvaughan
this t-case saver install instructions show you how to check the rear snap ring.
https://dodgeforum.com/forum/2nd-gen...ter-added.html
but - id guess the ticking to be a drive shaft u-joint.
first it ticks, then clicks. then clacks. then falls out.
Old Aug 3, 2012 | 10:17 AM
95RAM360's Avatar
95RAM360
I had a similar problem except after a while with the ticks she would try to go to 4x while your in 2wd and she would grind real bad....turns out my tcase shat the bed due to low/ no fluid
Old Aug 3, 2012 | 03:16 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Could be the Cardan joint on the front drive shaft.
Old Aug 5, 2012 | 01:51 PM
Purple5gear1500
Whatever it is I can feel in the shifter. I have just changed the fluid. and had the rear tail stock off and everything seemed fine.
Old Aug 5, 2012 | 02:02 PM
Purple5gear1500
I've checked U joints in the front also... I'm wondering if the chain spins in 2H along in 4 also. Does anyone know.
Old Aug 5, 2012 | 09:39 PM
dhvaughan's Avatar
dhvaughan
no. chain only turns in 4wd.
can you safely put the truck up on rear jack stands and run it and duplicate the sound.
Old Aug 6, 2012 | 04:03 PM
Purple5gear1500
Yea. I'll do that soon. I'll post a video to youtube. then put the link in here. Lemme know what you's think.
