skyjacker lift price
Old Aug 20, 2012 | 06:09 PM
merc225hp's Avatar
merc225hp
Just make sure you get ALL the parts needed.
Old Aug 20, 2012 | 09:45 PM
sleeper07's Avatar
sleeper07
Merc, getting: leaf springs, coil springs, shocks, steering stabilizer, shackles, and u-bolts. Am I missing anything?
Lone, thanks for the heads up.....only want to go 2".
Old Aug 20, 2012 | 09:59 PM
merc225hp's Avatar
merc225hp
If you are going 2" that's about it. 4-5" needs more than that, upper and lower control arms and brackets, drop pitman arm, some type of trac-bar for the desired lift, longer brake lines. While you are in there check all your ball-joints, u-joints, etc and get an alignment when done.
Old Aug 21, 2012 | 05:30 AM
Lone136's Avatar
Lone136
I would also do the front wheelbearings if you haven't done so. They are a none weak link in our trucks.
Old Aug 21, 2012 | 02:58 PM
sleeper07's Avatar
sleeper07
Thanks guys. Will try to post pics of before/after. I will also check bearings, u-joints, etc.
