PLEASE HELP ME IM DUMB!!!!
Old Aug 26, 2005 | 06:15 PM
LostSoul's Avatar
LostSoul
Default RE: PLEASE HELP ME IM DUMB!!!!
To go any bigger than 4:56, you would need to change the Carrier as well, and as stated, you cannot run a different ratios front and back unless you have differnet tires, (ie) Mud Boggers that run bigger rears. T-cases do not like that kind of stress.
Old Aug 26, 2005 | 08:29 PM
richardmoore's Avatar
richardmoore
Thanks, i'll def go with the 4:56's. How much higher will that make my truck rev going down the road?
Old Aug 26, 2005 | 08:33 PM
Silver_Dodge's Avatar
Silver_Dodge
With the larger tires, you may not notice any difference. Go to this website, and use the RPM calculator to see. Compare against your stock numbers.
http://www.differentials.com/calc.html
Old Aug 27, 2005 | 08:42 PM
richardmoore
thanks, yea when i put the bigger tires on i noticed that my rpms went down riding around, so i guess the gears should even things out.
