RWAL not working
Old Aug 8, 2012 | 12:20 AM
RageGuy's Avatar
RageGuy
Default RWAL not working
I started this other topic, but It didn't really state my main issue very well...
https://dodgeforum.com/forum/2nd-gen...ml#post2841388
My main issue is that my RAWL does not function. All fuses and relays check out, and I do not have a CEL indicating the rear ABS sensor is malfunctioning. ABS Light on my Dash comes on momentarily at start up then goes away (Normal operation I assume)
Old Aug 8, 2012 | 12:24 AM
crazzywolfie's Avatar
crazzywolfie
i would guess if your RWAL is working properly if your abs light is not staying on. why do you think it is not working?
Old Aug 8, 2012 | 06:37 AM
kejobe's Avatar
kejobe
The RWAL was just a joke by Dodge. Most of the time it doesnt work on these trucks. Every so often there will be one than does though.
Old Aug 8, 2012 | 02:29 PM
RageGuy's Avatar
RageGuy
This past winter all 4 wheels locked up on ice, also, I am assuming as with every ABS system I have ever seen, there is a noticble noise when the ABS is operating.....I have heard no such noise. Thus, I assume it is not functioning.
Old Aug 8, 2012 | 02:35 PM
billcart's Avatar
billcart
It does function, just not often. It is not that well of a designed system. If you have 4 wheel anti-lock you would be able to feel it. Like Kejobe said the RWAL is a joke so pump your brakes... lol
Gary-L's Avatar
Gary-L
Veteran: Navy
Learn to pump your brakes rather than depending on or using anti-lock brakes. Doing so will make you a better and more in control driver.
Old Aug 8, 2012 | 04:46 PM
crazzywolfie
it is only rear wheal anti lock system. i think in order to even really notice it working you have to drive an older vehicle without it. i know i don't feel it working on my 93 but under same circumstance my 81 would usually lock up the rear tires and slide around a bit where my 93 would just go straight.
Old Aug 8, 2012 | 06:07 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Why the hell did you start another thread about the same issue, when you have not even done the troubleshooting suggested in the other thread??????? Unreal, I don't know what else to say, except good luck. jeez
