cant figure out whats wrong
Old Aug 10, 2012 | 07:00 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by mike1991
i had redone it about 9 months ago probably what took the cat out
How did the plenum gasket get fixed? Just the gasket or did you replace the pan as well?
Old Aug 10, 2012 | 08:21 PM
Backfire isn't caused by lack of a cat..... nor is mufflers blowing up. Sounds like maybe a leaky injector, or a valve that isn't sealing as well as it should.
Old Aug 11, 2012 | 01:05 PM
mike1991's Avatar
mike1991
New Member
back fire is created by lack of o2 sensor when there is no cat by no cat i mean its off at the manifolds so yes no back pressure no o2 sensor on a 99 = back fire its not an 89 which would also have a back fire if reved and the lack of a cat will put excessive heat in the muffler of any kind due to the fact they are not designed to burn of gasses which would happen at that point
and to answer your question about the gasket i replaced the pan also and i rebuilt the tranny then
Old Aug 11, 2012 | 01:26 PM
ReadRam's Avatar
ReadRam
What? No cat would allow more unburned hydrocarbons out the tail pipe, not more heat.
Old Aug 11, 2012 | 02:06 PM
dlyter09's Avatar
dlyter09
My cat is gone also and it dont backfire at all.. You got something else going on..
Old Aug 11, 2012 | 03:35 PM
zman17's Avatar
zman17
You didn't fool around with the distributor adjustment when you did the plenum did you?
Old Aug 11, 2012 | 03:52 PM
mike1991's Avatar
mike1991
New Member
no i didnt it ran fine for 8 months
Old Aug 11, 2012 | 04:14 PM
zman17's Avatar
zman17
Have you tested and verified the fuel pressure is correct also?
Old Aug 11, 2012 | 04:21 PM
mike1991's Avatar
mike1991
New Member
yea the fuel is fine it was the first thing to get checked it was at 49psi
