Truck dies while driving then won't start right away
Old Aug 14, 2012 | 02:59 PM
zman17's Avatar
zman17
Retired Moderator - RIP
So did you try the things suggested in your threads?
Old Aug 31, 2012 | 11:33 AM
Robertm1212's Avatar
Robertm1212
Yes and it's still doing it. Anyone know where I can pick up a used computer?
Old Aug 31, 2012 | 02:10 PM
Robertm1212
I know you have to match a number on the computer but witch one is it I can't find any computers that come close to the numbers on mine. Thanks for the help
Here is a pic of my computer
Old Aug 31, 2012 | 02:25 PM
95RAM360's Avatar
95RAM360
Have you tested fuel pressure? You can test it right at fuel rail and should be around 49psi...
Old Aug 31, 2012 | 03:44 PM
zman17's Avatar
zman17
Assuming you've replaced the crank sensor. The # for the PCM you want is the # after where it says Chrysler in your pic. You can get a PCM with the same #'s with the last 2 letters being different. Yours has AD at the end . That's the important part of the P/N. If you find a PCM with the same #'s and those 2 letters at the end are AF for instance, it should work good enough to get you to the dealer so they can flash the PCM.
And btw, I can't find it right now, but Merc225 has posted cross reference #'s for the PCM's. Maybe he will chime in.
Old Aug 31, 2012 | 06:22 PM
Robertm1212
I have swapped the crank senor. It's getting worse like shutting off every 15mins I drive and it's taking longer for it to turn back on.
Is there anyone on here that repairs them?
Old Sep 1, 2012 | 08:21 AM
Need to find out what's missing when it won't start, spark, or fuel.
Old Sep 1, 2012 | 01:20 PM
zman17's Avatar
zman17
PCM could be bad or you have a defective crank sensor.
Old Sep 1, 2012 | 01:33 PM
corvetteed's Avatar
corvetteed
Default Mine Stalls too
I have a 2001 Dodge Ram 1500 5.9 also. It quits very often but starts right back up. It runs like there is someone turning the truck off and on then it dies. I have replaced the fuel pump assy and also the computer. There are no codes showing on the dash. Help
Old Sep 1, 2012 | 01:59 PM
merc225hp's Avatar
merc225hp
I have posted cross reference number's for pcm's but I have lost that sheet due to a HDD failure and a bad pc opt for not backing his info up.
I will see if I can find it again.
