Truck dies while driving then won't start right away
Old Sep 1, 2012 | 02:20 PM
  #21
merc225hp's Avatar
merc225hp
Found it
This is what I come up with.
99 BR/BE 5.2L M5 FED PCM
05018488AA
56040081AA
56040081AB
56040081AC
56040081AD
56040081AE
56040081AF
Revision number 56040081AG 18-004-02
TSB number's for these pcm's
18-030-01
18-25-99
18-35-98
18-36-98
18-37-98
For those that would like to dl this sheet.
https://docs.google.com/open?id=0B8u...09lQVVXMFlTSk0
Old Sep 1, 2012 | 04:19 PM
  #22
Robertm1212's Avatar
Robertm1212
So now it shutdown on me a again and isn't starting back up I put my obd2 reader on it and it wont connect is saying error and on the dash it's saying no bus
Old Sep 2, 2012 | 04:05 PM
  #23
corvetteed's Avatar
corvetteed
Default Next Part
I'm going to replace the crank sensor. Amazon has them for $16 and change. Regular price is $50, it's a great deal.
Old Sep 2, 2012 | 04:11 PM
  #24
It's only a great deal if it actually works........
Old Sep 2, 2012 | 07:49 PM
  #25
sbulla's Avatar
sbulla
My 2K 5.9 had similar symptoms and it ended up being the PCM. I replaced it with one from Auto Computer Exchange for about half the price of a new one and, it's run fine since.
Good luck,
Sonny
Old Sep 2, 2012 | 09:00 PM
  #26
Robertm1212
I ordered a reman PCM from oriellys today should be here Friday. It is coming flashed ready to put in for 289 and comes with a year warranty.
Old Sep 2, 2012 | 10:24 PM
  #27
zman17's Avatar
zman17
Retired Moderator - RIP
Found it
05018488AA
56040081AA
56040081AB
56040081AC
56040081AD
56040081AE
56040081AF
18-030-01
18-25-99
18-35-98
18-36-98
18-37-98
Thanks bud.
Old Sep 3, 2012 | 08:38 AM
  #28
njgerry's Avatar
njgerry
I had the same problem on my V8 Ram Van. I wiggled the right most connector and it worked for a few days. Then the "no bus" - no start message; Wiggled again - okay for a few days...... Eventually figured out that there is a bad connector in the PCM. Ordered a new one from Auto Computer Exchange - installed it - everything works 100% again
Gerry
Old Sep 3, 2012 | 12:58 PM
  #29
Robertm1212
I've tried that also and it was still doing it.
Old Sep 4, 2012 | 08:53 AM
  #30
corvetteed's Avatar
corvetteed
Default Codes
How do you stop throwing parts at the problem when the computer won't give you a code to fix the problem ???
