Cold Idle issue - truck whines/hisses and RPMs drop way down almost to stall.
You unplug the o2, move the wire/connector out of harms way, and pull the o2 from the pipe/cat. Then test drive. But in his case, the problem was noticeable at idle.
consider yourself lucky. my truck eats money in larger bites, usually hundreds of dollars at a time,
So does mine brother. First it was a coolant leak, then timing chain, then hub studs, then transmission, then TWO transfercases and driveshafts.... the only nice thing ive done to the truck otherwise are spark plugs and an oil change. And new valve cover gaskets. (Sorry for being offtopic)
Are you supposed to actually remove the pre-cat 02 sensor from the converter or simply disconnect the wired connection ,or both?
Disconnecting the sensor tests to see if the sensor is bad. (which in your case, I do believe is indeed the problem.) Removing the sensor from the cat, tests to see if the cat is getting clogged. (if it runs better with the sensor removed, that indicates the cat is on its way out.)
