Trip computer recommendations?
Old Aug 15, 2012 | 11:11 PM
flyingdutch16's Avatar
flyingdutch16
Default Trip computer recommendations?
Hi,
I've been looking at some diagnostics and trip computers. Now i figured first i just wanted a diagnostics reader that i can just plug in to see what is wrong. But then I found out about the scangauge trip computer and i figured i'd be nice to beable to see my MPG's actual RPM accurate reading of gas left till empty(gauge is so off right now) Anyways the thing i dont like about the Scangauge is that the screen is so small. So does anybody know off one with a bigger screen?
Old Aug 16, 2012 | 12:37 AM
Jason_Dodge's Avatar
Jason_Dodge
You can buy an elm327 bluetooth adapter. It plugs into your OBD and connects to your cellphone using an application. If you have a smartphone, you can easily get and app such as torque to see your mpg and other diagnostics like heattemp and rpm. Theres a ton more you can view. You can also check codes and whatnot. Its only 25 bucks off amazon.
Old Aug 16, 2012 | 12:38 AM
Jason_Dodge
I have it and it works fantastic. I got tired of driving 5 miles to see what a check engine code was so i bought it and i use it all the time on my friends cars aswell. A nice way to make a few bucks here and there.
Old Aug 16, 2012 | 09:03 AM
Keep in mind, your PCM gets its information on how much gas is in the tank from the same place the gauge in the dash does.... the in-tank sending unit.....
Old Aug 26, 2012 | 10:04 PM
flyingdutch16
the bluetooth ones only work with the androids i have an iphone haha. Im probably going to settle for a scangauge unless i find something with a bigger screen in the same price range.
