How do you find a vacum leak?
Old Aug 26, 2005 | 04:11 PM
richardmoore's Avatar
richardmoore
Default How do you find a vacum leak?
I have the same vacum leak problem that ya'll have talked about before that makes your AC act funny. I can't for the life of me figure out which line it is or where to start looking. Thanks
Richard
Old Aug 26, 2005 | 05:41 PM
steve05ram360's Avatar
steve05ram360
Default RE: How do you find a vacum leak?
there should be a vacuum line going into the firewall near the heater core... there is a check valve that goes bad and causes a leak and also your ac vents will go to defrost when it is not working
Old Aug 26, 2005 | 05:56 PM
richardmoore
Is that check valve green and over on the passenger side?
Old Aug 26, 2005 | 06:18 PM
LostSoul's Avatar
LostSoul
I used carb cleaner to find mine on the Cherokee, I srayed it lightly around the lines untill I found a spot that made the engine rev up.
Old Aug 26, 2005 | 08:24 PM
richardmoore
thanks i'll give that a try.
Old Aug 28, 2005 | 12:21 AM
4DrMopar's Avatar
4DrMopar
IF ya want something simple and you have a torch, simply turnon the Acetelyne part, dont light anything wave it across the vaccumlines... I have seen Carb cleaner make the ****ty plastic lines MORE brittle
Old Aug 28, 2005 | 07:29 PM
richardmoore
Yea I've got a torch. I'll have to give that a try. I tried starter fluid but that didn't seem to work very good.
