Am I misjudging my NV4500?
I swapped out my NV3500 for an NV4500. This costed me around $2500 for tranny, transfer case (an NP241HD) and driveshaft mods. This thing was used when I bought it, and it shifts like an '88 Ford dumptruck we had at one time. I was reading a diesel mag and saw an article where the dude "didn't like the way his NV4500 shifted" and bought a Ford ZF-6 to replace it. My question is this; is this thing simply worn out? Or must I give up speed-shifts and settle into a life of forever double-clutching for the strength? A reman was quoted at $1600 after core, and I need to decide if I'm settling with this one or not. I have seen plenty of diesel drag trucks with the NV4500.....
Does it grind? If it's grinding, the synchros are worn out.
I've only driven an NV4500 in a CTD and I thought it shifted better than my NV3500.
They're both truck trannys and are never gonna like speed shifting. It'll only wear the synchros out faster.
Do you have the correct fluid in it?
Okay, I literally need to double shift this thing. Fourth gear is so slow, I literally lose all forward momentum and begin to decelerate before I can "slide" it in. And third gear is getting bad. My Dad said to just get regular gear oil, and for the first couple hundred miles I did, but then I bought Amsoil's version of Syncromesh. I don't need a dragster. But having to wait more than two seconds before I can "feel" it into gear is driving me insane. BTW, is it rebuild-able? I heard you need a 200 ton press or something.
