Speed
Old Aug 19, 2012 | 04:29 PM
Mutt Bryant's Avatar
Mutt Bryant
After the tune up (providing it didnt work) could a fuel filter that is stopping up or dirty injectors be the problem?
Old Aug 19, 2012 | 04:32 PM
95RAM360's Avatar
95RAM360
What are the rpms at top speed?
Old Aug 19, 2012 | 04:44 PM
charlie1935's Avatar
charlie1935
Originally Posted by QuadCabLuv
Are you sure your getting into 4th gear?
My 1500 with 318 & 3.55 gears with 30.6 inch tires will do 114 in 3rd.
Just over 4300 RPM.
O/D is so high geared it probably won't do that in 4th.
Old Aug 19, 2012 | 04:45 PM
Mutt Bryant
bout 2 1/2. It doesnt go to a higher rpm in 4th even with the pedal to the floor
Old Aug 19, 2012 | 04:46 PM
Mutt Bryant
Correction, in 3rd
Old Aug 19, 2012 | 04:47 PM
dlyter09's Avatar
dlyter09
Possible transmission issue?? If it was motor you would think it should run like crap all the time
Old Aug 19, 2012 | 04:49 PM
Mutt Bryant
I dont think so. Trans works fine in normal driving. It could be a throttle thing. idk
Old Aug 19, 2012 | 05:23 PM
ReadRam's Avatar
ReadRam
Did you check if accelerator cable isn't stretched out or somehow not opening throttle fully. Have someone press gas pedal while you observe throttle lever movement with engine off. Does it ping,rattle or misfire bad at top end?
Old Aug 19, 2012 | 06:20 PM
Ham Bone's Avatar
Ham Bone
That sounds real similar to a clogged cat, but you apparently don't have cats anymore
Old Aug 19, 2012 | 06:37 PM
Mutt Bryant
Aint checked the cable yet but will do. Its got a aftermarket hand throttle from the fire department that owned it before me and I've been suspecting that it might be adjusted low or something.
