Tranny question
Old Aug 19, 2012 | 03:28 PM
DoubleL24's Avatar
DoubleL24
Default Tranny question
I have a 99 ram and I had my transmission rebuilt. I dont drive my truck much due to having a work truck. When my truck sits for awhile and I get in it and try to go it kind of hesitant on moving. Anyone know what this would be or if this is normal? Also sometimes it wont start in park i have to put it in neutral. Is there something I can adjust? thanks
Old Aug 19, 2012 | 03:38 PM
QuadCabLuv's Avatar
QuadCabLuv
Did they delete the check valve? If they did then that explains the hesitation. Try puttin in in nuetral first for about 15 sec to give it time to fill torque converter back up.
Old Aug 19, 2012 | 03:40 PM
DoubleL24's Avatar
DoubleL24
Im not sure what they did. Cost me like $1500 for them to rebuild.
Old Aug 19, 2012 | 03:42 PM
QuadCabLuv's Avatar
QuadCabLuv
Well look and see if its there. Do a search for check valve delete. Ther are numerous threads on it. It will show you where to look.
Old Aug 19, 2012 | 03:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1... I'd check the fluid level any way for the hell of it. Hot and in neutral.
Old Aug 19, 2012 | 03:49 PM
zman17's Avatar
zman17
$1500 and you don't know what they did? Hmm Call ask them for a build sheet of what they did to your truck.
Old Aug 19, 2012 | 07:13 PM
dhvaughan's Avatar
dhvaughan
starting in park or neutral is controlled by "neutral safety switch". drivers side of transmission.
a condition called torque converter drainback can cause the torque converter to drain its fluid. solution/workaround is to let the engine run in neutral for about a minute or so to pump it back full of fluid. pump doesn't run in park.
Old Aug 19, 2012 | 09:56 PM
gdstock's Avatar
gdstock
+1 on what has been said about letting it idle in neutral for a minute (or less) to refill TC.
The linkage is probably misadjusted. a mere 1/32" out of adjustment can keep it from starting in park. Put truck in park, loosen bold on linkage rod. Make sure to push lever all the way into stop position and retighten bolt. ( I think it is a 12mm bolt.) Check and see if it will start in park now. Other option is to take it back to shop that rebuilt tranny....
