Front end
Old Aug 21, 2012 | 08:13 PM
bassetthunt's Avatar
bassetthunt
Default Front end
I have a 95, 2500 cummins, reg cab long bed. I had a problem once before with going down the highway at 65-70 and hit a hole, all the sudden the truck starts shaking and dosent stop untill I completly stop. I took it to a shop the said it was all the steering links bars shocks and so on but not the ball joints. I replaced all that 5ish years ago and it is doing it again. it only has maybe 15000 miles on it since then. Does anyone have any other ideas. Thanks in advance.
Old Aug 21, 2012 | 08:24 PM
stewie01's Avatar
stewie01
Is is 4x4 or 4x2? Death wobble maybe?
Old Aug 21, 2012 | 08:33 PM
bassetthunt
Default front end
Its a 4x4 and yes the death wobble is the closest thing i can find. never saw a fix.
Old Aug 21, 2012 | 08:46 PM
95RAM360's Avatar
95RAM360
Have you jacked it up and wiggled the tires....and when its on the ground have someone turn the wheel back and forth but dont turn the wheels and just check all the joints....
Old Aug 21, 2012 | 09:41 PM
gdstock's Avatar
gdstock
Double check the parts you replaced 15,000 miles ago.....If they were inexpensive ones ( ) they may need replacing again. And double check the ball joints as well.
