Best way to remove bezel on 2000 ram???
Old Aug 22, 2012 | 07:53 PM
1stGenDak's Avatar
1stGenDak
Default Best way to remove bezel on 2000 ram???
I just bought a new ram and I need to get behind the aftermarket radio which means I need to remove the bezel. I have never had to do this before so i do not know any tricks. If you know of something that keeps the bezel from breaking please let me know.
Thanks,
Zac
Old Aug 22, 2012 | 08:24 PM
ReadRam's Avatar
ReadRam
Just did my last night. I started pulling out at bottom left corner then just work it out little bit at a time. You will have to put steering wheel and gear selector all way down to take all the way off. If i can do it, you can do it.
Old Aug 22, 2012 | 09:08 PM
dhvaughan's Avatar
dhvaughan
use a wide, stiff putty knife to gently pry it loose. pry as close to clips as you can get.
Old Aug 22, 2012 | 09:41 PM
ReadRam's Avatar
ReadRam
Forgot to mention, I had the panel off under steering wheel which made it easy to pull bezel out at the bottom, then just worked my way around up around the sides ,then the top...didn't need any tools,
