odd engine code
Old Aug 27, 2012 | 06:02 AM
chelios1368's Avatar
chelios1368
Default odd engine code
Hey y'all
So I've just gotten the oddest engine code I've seen...(engine cold too long) I can't remember the code number off the top of my head. Also my temp Guatemala will barely creep off zero even after driving for a good distance. I'm thinking It's my ect sensor but wanted to see if any has ran into the same problem. Any advice would really help. Thank you!! Also i have an 01 sport with a 5.2.
Old Aug 27, 2012 | 06:03 AM
chelios1368
*guage....not Guatemala........stupid phone.
Old Aug 27, 2012 | 10:50 AM
kejobe's Avatar
kejobe
I get that code when its cold out. But then I have a 180* stat for the SCT though.
If it was fine then just started, it could be the stat is stuck open or the temp sensor is bad. Neither are very hard to change, nor are they very expensive.
Old Aug 27, 2012 | 03:42 PM
Wombat Ranger's Avatar
Wombat Ranger
Mine did the same when I got it, it had a 180* stat too. If you think it's the temp sensor, replace it. They are like $3 on rock auto.
Old Aug 27, 2012 | 09:57 PM
Jason_Dodge's Avatar
Jason_Dodge
I'd say replace the stat. The 180 is only good if you use a tuner and they are more prone to failure. Atleast you had the failsafe one. Just replace with a good stat, top off fluids, and you're good to go.
Old Aug 27, 2012 | 10:50 PM
dhvaughan's Avatar
dhvaughan
P1281. Engine too cold too long.
replace t-stat. get the good Stant Superstat for about $12-15.
Old Aug 28, 2012 | 07:08 AM
chelios1368
Yea I made the mistake of posting a new thread before researching out of pure frustration. Haha thanks for the advice but I went and bought a 195* thermostat and a new ect sensor....and presto problem solved....on to my next problem of evaporation leaks.....that ones gonna be a little more time consuming...thanks again all.
Old Aug 28, 2012 | 07:13 AM
dhvaughan's Avatar
dhvaughan
P0442, P0455 see here
https://dodgeforum.com/forum/2nd-gen...-leak-fix.html
Old Aug 28, 2012 | 07:40 AM
chelios1368
Thanks for the link that'll deffinetly come in handy!
