Bad Driveshaft U-Joints?
Old Aug 28, 2012 | 11:47 PM
CharlieSheenWins's Avatar
CharlieSheenWins
Default Bad Driveshaft U-Joints?
Hello everyone, so for the past few months I've had a high pitched squeaking sound coming from the rear of my truck. It only occurs under acceleration when the truck hits the slightest little bumps and changes in the road surface. Speed is not a factor but it is harder to hear when going faster because of wind, road, and truck noise. Could it be u-joints? leaf spring bushings? The shocks are 1 year old so I doubt its them.
Its progressively become worse and is getting very annoying.
I just fixed my squeaky brakes and leaking steering box so now this. Thanks Dodge
Old Aug 29, 2012 | 12:00 AM
95RAM360's Avatar
95RAM360
Grab the driveshaft while its in park and turn it back and forth you should be able to tell that way...my driveshaft will not move at all when in park but i did just do that ujoint about 9the months ago...
If you do change it get a greaseable ujoint...got mine for $11 and took me about half hour to change
Old Aug 29, 2012 | 12:04 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
U joint.
Dad's truck did the same thing, only both were shot.
Old Aug 29, 2012 | 12:25 AM
kejobe's Avatar
kejobe
Mine squeaked also. Except there was no noticable play, but they were bad.
Old Aug 29, 2012 | 05:45 AM
Lone136's Avatar
Lone136
You will not always get movement in a bad Ujoint.
Old Aug 29, 2012 | 07:10 AM
dhvaughan's Avatar
dhvaughan
squeaking is usually how they start, then it can progress into a click.
as said, test by twisting the u-joint back and forth. ANY movement is bad. also visually inspect the seals around the caps. should be intact, tight, etc. if nothing obvious, stick a large screwdriver through the cross and pry back and forth with a little more leverage. any movement indicates it needs replacement.
+1 on greasable, but i recommend the more expensive Precision brand Super-Strength greasables. they're more expensive at $20-30 but worth it.
Old Aug 29, 2012 | 04:17 PM
CharlieSheenWins
Thanks everyone. I figured it was a u joint. I believe its going to be the front driveshaft u joint because the rear u joint was replaced already after I blew it plowing over a big snow pile in reverse.
Old Aug 29, 2012 | 04:27 PM
Front driveshaft shouldn't be turning if you aren't in 4wd.....
There are two u-joints in the rear shaft though......
Old Aug 29, 2012 | 04:28 PM
CharlieSheenWins
I see the confusion haha sorry I worded it that way. I meant the front u joint on the rear driveshaft.
Old Aug 29, 2012 | 04:33 PM
LOLOLOL.
Ok, that makes more sense.
