Wheres the fuel filter located on a 96?
Old Aug 28, 2005 | 06:27 PM
nmason's Avatar
nmason
Default Wheres the fuel filter located on a 96?
doing alot of small things on the truck this weekend. one of the last things left is to change out the fuel filter, but i cant find it under there. can anyone point me in the right direction?
thanx
Old Aug 28, 2005 | 07:44 PM
Spartan's Avatar
Spartan
Default RE: Wheres the fuel filter located on a 96?
As far as i know there isnt one....it is a "sock" located inside the fuel tank and simply works like a filter.....this could be total BS but it is what i was told after i had the same problem of being unable to find it....if its BS PLEASE let me know someone!
Old Aug 28, 2005 | 09:04 PM
nmason's Avatar
nmason
i had a reply on another site saying the filter is in the tank. and yes, there is a filter.
Old Aug 29, 2005 | 12:06 PM
johnbgunther's Avatar
johnbgunther
I just had my fuel pump changed in trying to solve my dilema (see 360 engine keeps flooding: https://dodgeforum.com/m_283876/tm.htm). I was told that the fuel pump is one big unit and is where the filter is located. So, it sounds to me like you would need to remove the fuel pump to change the fuel filter and that my friend is no easy task especially if the tank is full.
Old Aug 29, 2005 | 05:20 PM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: johnbgunther
That's why you empty the tank before you drop it Uneless your pump is COMPLETELY dead. In that case, you're SOL [:'(]
The pump and filter are one unit. And if you go through the trouble of dropping the tank, you're better off replacing the whole pump...because it's something you're not gonna want to do again.
Old Sep 2, 2005 | 12:57 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Based on my research, you'd better have a fuel pump problem before dropping the tank. Everything I've found states the the fuel pump backflushes the filter upon startup. Dodge always has to do everything *different* than everyone else. Sometimes different is good, but this is one of those times I seriously doubt that.
