changing trans oil at 72k miles
Old Sep 7, 2012 | 07:18 PM
boxer15's Avatar
boxer15
Default changing trans oil at 72k miles
So, I had a basic trans oil pan change done at 40k miles and my oil is still clean however I was planning to get the full change done where they change all oil and flush out the oil from trans. However, I read that the trans on these trucks get used to the dirty oil and changing all of it to clean oil can make it slip? So, should i get the full change done or just drop the pan and change the filter?
my truck is a 2001 ram 1500, auto, 5.2 318 engine. Also, how often should the oil in the rear end be changed. I never had that done and was told that for 2nd gen rams they do go bad if they aren't changed.
Old Sep 7, 2012 | 07:27 PM
gdstock's Avatar
gdstock
Changing fluid and filter is OK. Do not do the "flush". Just draing, change filter, refill....
I don't know about the recommendation for changing gear oil in diff. Check out the service manual in the FAQ/DIY section here. You can download it. Service recommendations will be listed ther as well as the type of gear oil to use.
