oil pump options
Hey everyone. When I tear into my engine to do the plenum, water pump, timing chain, oil pan gasket and possibly rear main, would it be a good idea to put in a new oil pump? How about a higher flowing oil pump versus OEM? I searched on here a little bit with not much clarification. Pump works fine now but it's one of those things that if I'm working on it that much, what's a little extra work you know. thanks guys
Pull the puimp, take it apart and have a look...Check the clearances, I thinnk the info is in the FSM.
You don't need a HP oil pump unless your trying to build pressure on a worn out motor..I run stock pressure in my Drag truck, and some of the Melling HP pumps have been causing problems of late.
