1996 Ram 1500 P1899 code?
Old Sep 8, 2012 | 06:21 PM
reconrey's Avatar
reconrey
Default 1996 Ram 1500 P1899 code?
Well my Check Engine light came on yesterday and I plugged my code-reader and it gave me the code P1899 and said "No DTC definition." What does this mean? How do I fix it? It seems to run just fine...
Thanks.
Old Sep 8, 2012 | 06:25 PM
UnregisteredUser's Avatar
UnregisteredUser
It means "Park/Neutral switch stuck in Park or gear". I guess the hot ticket would be to test it with an ohmmeter to see if it is indeed stuck, and proceed from there.
Old Sep 8, 2012 | 06:38 PM
reconrey's Avatar
reconrey
It seems to drive and park fine? Wouldn't that effect that? And where is it located on the truck?
Thanks.
Old Sep 8, 2012 | 09:24 PM
Right below where the shift linkage hits the trans. Do your reverse lights work?
Old Sep 8, 2012 | 10:01 PM
reconrey's Avatar
reconrey
Well, I just did some Googleing, then I pulled the switch. And my truck was able to start in drive, which is what I read as one of the symptoms. So I am assuming that the switch was bad, I did not check the reverse lights.
Thanks.
Old Sep 9, 2012 | 11:45 AM
reconrey's Avatar
reconrey
Thanks for the help everyone! I just finished replacing the switch, cleared the codes, and the light is off! Thanks!
