Deleting the CEL after removing a cat
Old Sep 9, 2012 | 11:55 AM
Blue Mopar01's Avatar
Blue Mopar01
Default Deleting the CEL after removing a cat
I know HammerZ71 has a thread on this in DIY but my only question is what O2 sensor do I modify?
Old Sep 9, 2012 | 12:03 PM
merc225hp's Avatar
merc225hp
You put the non fouler's on the post or rear 02 sensor.
Old Sep 9, 2012 | 12:09 PM
zman17's Avatar
zman17
Retired Moderator - RIP
And reset the PCM by removing the negative battery for a few minutes. Which btw, should have been disconnected first, before you started the work.
Old Sep 9, 2012 | 08:28 PM
Blue Mopar01
I haven't done anything with it yet, just collecting some more insight. But thanks!
Old Sep 9, 2012 | 10:20 PM
Jdingman81's Avatar
Jdingman81
I just installed a Spintech Ypipe with no cat and i did the non fouler trick on the rear o2 and 1000 miles later no code
Old Sep 11, 2012 | 12:12 AM
It's Me Patt's Avatar
It's Me Patt
After a certain amount of cycles it will reset itself..I think mine is 40..And unless your working with the neg bat cable off it should be reset with a scan tool..congrats on your fix!
