Cylinder heads
Old Sep 12, 2012 | 10:43 AM
Adobedude's Avatar
Adobedude
Depends on what ya wanna do. if you are looking for more top end power, go with the larger valve heads. If not, stick with the stock size.
Yep...to take advantage of the 2.02s you need a lot. Gears, stall, cam, Manifold, TB, tuner....$$$ & more $$$
It's the correct a sum of parts for task at hand.
