Cylinder heads
Old Sep 11, 2012 | 06:01 PM
bondw001's Avatar
bondw001
Default Cylinder heads
Jyst wondering if the stock heads cracking is a common problem with our trucks. I took my heads in for a valve job and was told both are cracked. I spoke with a few machine shops locally and they all said that our heads are prone to cracking.
I'm looking at Odessa for new heads, but am sceptical to buy remanufactured heads if they are so prone to splitting.
Please help
Old Sep 11, 2012 | 06:05 PM
dlyter09's Avatar
dlyter09
Yea its common for the stock heads to crack. Odessa heads are a good replacement. The heads crack due to a blown plenum that clogs the cat and then the heads crack. Address those issues while your in that far
Old Sep 11, 2012 | 06:26 PM
bondw001's Avatar
bondw001
already fixed those, has a new walker high flow cat and I just installed the hughes plenum plate. So re manufactured iron heads from odessa should be a safe replacement then? I can't afford brand new heads
Old Sep 11, 2012 | 07:49 PM
dlyter09's Avatar
dlyter09
Yea your good with odessa. Thats what ill be getting in a few months
Old Sep 11, 2012 | 08:26 PM
bondw001's Avatar
bondw001
Thanks, I'll be ordering soon
Old Sep 11, 2012 | 10:56 PM
horatio102's Avatar
horatio102
Check hughesengines.com and look at the 4670B heads.
Old Sep 11, 2012 | 11:00 PM
Do NOT get the reman heads. Odessa also makes NEW heads, that are MUCH better castings, and less prone to cracking. The reman heads are exactly that. Stock factory heads that someone else got tired of, and used as cores, to purchase NEW heads.
Odessa makes the better heads in both stock valve size, and also larger valve flavors. You can even order them up with better valve springs for more lift, should you decide to do a cam swap while you are in there.... (hint hint )
Old Sep 12, 2012 | 07:28 AM
bondw001's Avatar
bondw001
Hughes is too expensive for my budget.
HeyYou, I found new complete heads from Odessa, thanks. What can would you recommend? remember, she's not a 4x4 lol
Old Sep 12, 2012 | 08:36 AM
dlyter09's Avatar
dlyter09
Oops! Didnt see he said reman... one to many adult beverages last night lol
Old Sep 12, 2012 | 09:58 AM
Depends on what ya wanna do. if you are looking for more top end power, go with the larger valve heads. If not, stick with the stock size.
