OOOOOOOOOver drive solenoid?
Old Sep 14, 2012 | 11:45 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Reddnek
ok im sorry guys im kinda getting confused here, so let me put it this way, 1. the trans right now is the trans from the 97 ram, it has the 97 solenoid & transducer set in it, it shift fine, no problems. i just dont have overdrive, so with that being said, according to z man, even though the 97 gov/transducer, work fine, they still need to be replaced?, or can i get away with just swapping out the tcc/od solenoid.
2 i dont quite believe my friend, but he thinks that somehow i can run a regular toggle switch or somehting of that sort on the dash(which im not in favor of) to get od to function, is that even a possibilty?
You need to do what I already stated. The gov solenoid is fine, but you should get one of these anyway. http://www.doghousediesel.com/catalog/i307.html
The transducer(pressure switch) needs to be replaced along with that bracket because you cant mount it to the gov body AND the new (correct for your year) TCC/OD solenoid assembly will not plug into the 97 transducer.
Old Sep 14, 2012 | 01:24 PM
Reddnek's Avatar
Reddnek
SO when I put the new parts in the plugs will be the same right?
Old Sep 14, 2012 | 01:42 PM
zman17's Avatar
zman17
Dude, you need all the parts for a 2000 simple as that. I don't know what to say that I have not already said.
