clunk feeling when stop and take off.
Old Sep 12, 2012 | 11:53 PM
Dig-N-Deep's Avatar
Dig-N-Deep
Default clunk feeling when stop and take off.
So I did some research and looked into that stuff but its not my problem : ( when I stop I feel a clunk in the steering wheel and in the pedal and I feel the same thing when I take off. I'm confused because I'm not a noob and I also have a lot of automotive knowledge the only thing I can think it is would be the steering shaft from column to gear box any help is appreciated thanks guys
Old Sep 12, 2012 | 11:59 PM
Matt Nickerson's Avatar
Matt Nickerson
Take a look at this http://rocksolidramtrucksteering.com/
If you're feeling a clunk in the brake pedal that could be another problem with the brakes themselves or a bad hub bearing.
Old Sep 13, 2012 | 12:13 AM
Dig-N-Deep's Avatar
Dig-N-Deep
Thanks ill check into that more. And all new bearings, ball joints, tie rods and breaks so that's why I'm confused. It's mainly in the column kinda like the column moves in and out but its tight trust me its not moving in or out. Any more info or if anyone else is having this problem please help me explain what I'm feeling to others
Old Sep 13, 2012 | 01:46 AM
kejobe's Avatar
kejobe
If 4x4 check the lower shock bolts also. Should be torqued to (iirc) 105 ft/lb.
Old Sep 13, 2012 | 02:25 AM
Dig-N-Deep's Avatar
Dig-N-Deep
Yes it is its a 1998 4x4 sport sorry I didn't say that. Well ill check that thanks
Old Sep 13, 2012 | 02:34 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Other thoughts: brakes secured, body mounts, trackbar mount, swaybar, etc.
Old Sep 13, 2012 | 02:39 PM
merc225hp's Avatar
merc225hp
Control arm bushings at the frame end should also be checked.
Old Sep 14, 2012 | 12:38 PM
Dig-N-Deep's Avatar
Dig-N-Deep
Thanks guys ill let you know later after I go over it all again don't want to leave everyone not knowing what it is if someone else is having a problem.
Old Sep 14, 2012 | 01:25 PM
QuadCabLuv's Avatar
QuadCabLuv
Any chance it could be the u joints?
Old Sep 14, 2012 | 01:38 PM
Dig-N-Deep's Avatar
Dig-N-Deep
Checked them when I put the new tcase in all are good
