1997 Ram Sport 4x4 stalling
Old Sep 13, 2012 | 05:36 PM
JLimb's Avatar
JLimb
Default 1997 Ram Sport 4x4 stalling
My son has a 1997 Ram Sport with the 5.2. The truck started stalling all the time. All vacuum lines have been replaced and it isn't throwing any codes. It only seems to stall now on declines and when stopping. Could it be a fuel pump issue ?
Old Sep 13, 2012 | 07:36 PM
Matt Nickerson's Avatar
Matt Nickerson
Disconnect the negative battery cable. Pull off the throttle body and take out the Idle Air Control valve. Clean the throttle body, the tip of the IAC (being very careful not to twist or push or pull on it), and the passage that the IAC sits in. Put everything back together and start it. Is it all better?
If not, get a fuel pressure gauge and measure fuel pressure with a running engine and record the PSI (should be around 49psi) then turn the engine off and observe how the pressure holds, or doesn't hold (pressure should drop off very slowly).
Let us know what you find.
