Trans issues 46re
Old Sep 14, 2012 | 02:46 PM
Hiyaguy's Avatar
Hiyaguy
New Member
Default Trans issues 46re
Hello all,
I have a 2000 Dodge ram 1500 4x4 5.9L 360. I think its the 46re?
It goes in reverse, and also drive. Doesnt want to shift into any other gears without letting off the pedal and it shifts hard. So now im making a checklist of issues and Im going to start replacing parts. All im asking is what should i start with, I have a small list started already but Im not all sure what to begin replacing is all.
Output speed sensor, throttle position, gov. pressure, transducer.
Anything to add and what should i start on (hopefully the first few things will fix it?) Thank you!
Old Sep 14, 2012 | 03:54 PM
Vegas360's Avatar
Vegas360
Bad transmission gov pressure sensor and solenoid? Maybe try adjusting the TV cable for the transmission. Could be out of spec.
Old Sep 14, 2012 | 04:07 PM
fiord of norway's Avatar
fiord of norway
Governor pressure solenoid and sensor,fixed mine...PO didn't put the magnet back in the pan so I've got sludge though the whole system,gonna rebuild one from the JY and have it on stand bye...the DIY and FAQ section has excellent info and manuals ....
