46re Transmission Blues
Old Sep 15, 2012 | 03:11 PM
skydog's Avatar
skydog
Default 46re Transmission Blues
99 1500 4WD, 123k miles. Was shifting fine. One day it started to stay in 1st gear until about 3500 rpms before shifting into second. Everything else seems to be shifting ok. Also can get it to shift earlier by blipping the throttle a bit. Replaced the governor solenoid and pressure sensor with the Brog Warner parts. No shavings in the pan, just some sludge on the magnet. Still does it. ughh. Any other ideas?
Old Sep 15, 2012 | 03:59 PM
dlyter09's Avatar
dlyter09
Did you adjust the bands while you were in there?
Old Sep 15, 2012 | 04:17 PM
skydog's Avatar
skydog
No, I did not
Old Sep 15, 2012 | 04:29 PM
dlyter09's Avatar
dlyter09
Id say try that. How is fluid level and how does it smell? Not burnt?
Old Sep 15, 2012 | 04:55 PM
skydog's Avatar
skydog
level ggod and not burnt. That's why I was certain it was the governor..
Old Sep 15, 2012 | 05:20 PM
dlyter09's Avatar
dlyter09
Band adjustment is probably your best bet right now.
Old Sep 15, 2012 | 06:17 PM
dlyter09's Avatar
dlyter09
Before the band adjustment check the TV cable
Old Sep 15, 2012 | 07:34 PM
skydog's Avatar
skydog
Would a TV cable adjustment change shift points for all gears changes? Its just 1st to 2nd that is off...
Old Sep 15, 2012 | 07:47 PM
dlyter09's Avatar
dlyter09
Its worth a shot to check. Saves you from spending money on more ATF
Old Sep 15, 2012 | 08:02 PM
skydog's Avatar
skydog
Roger that...thx
