46re Transmission Blues
Old Sep 21, 2012 | 01:07 AM
  #21
dhvaughan's Avatar
dhvaughan
where are you located?
after its all over post your recommendations on your transmission shop.
Old Sep 21, 2012 | 07:21 AM
  #22
skydog's Avatar
skydog
Will do. Transmission shop is in Springfield Mass. Should have the truck back today/
Old Sep 21, 2012 | 04:59 PM
  #23
skydog's Avatar
skydog
Got the truck. Shifts great. Reading from the invoice:
(tuff to read)
Replaced clutches, steels, seals, gaskets, orings, washers, sealing rings, sprag, intermeditate band, bearings, low band, overhaul valve body, front drum, overhaul pump, torque converter, transmission mount, all updates,....O/D section rebuilt also.
$2100 tax included 12 month, 12k warranty
Old Sep 21, 2012 | 07:53 PM
  #24
OUch, that's expensive.....
Old Sep 21, 2012 | 08:32 PM
  #25
dlyter09's Avatar
dlyter09
Wow!! $2100... I would have just bought a Mega Viper instead of getting a stock rebuild...
Old Sep 21, 2012 | 08:52 PM
  #26
dhvaughan's Avatar
dhvaughan
well, maybe, maybe not. the internet purchased viper is very damn expensive, and does not include R&R, which is several hours on a 4wd. so if you had to pay someone to do that, you might be looking at $3000+
Old Sep 21, 2012 | 09:06 PM
  #27
UnregisteredUser's Avatar
UnregisteredUser
My Mega Viper, with the upgrades I wanted, was $3447.90 delivered. R&R labor certainly not included in that. By the time I was done the bill was north of $4200.
Old Sep 21, 2012 | 10:21 PM
  #28
stewie01's Avatar
stewie01
I would put the transmission through its paces while under warranty, get any kinks worked out this way.
Old Sep 22, 2012 | 12:02 AM
  #29
gdstock's Avatar
gdstock
(tuff to read)
WOW! Maybe I should open a trans shop...only rebuilding 46RE trannys!
Old Sep 22, 2012 | 08:10 AM
  #30
skydog's Avatar
skydog
Don't forget ....this is CT/Mass Everything is more expensive up here. Also, this guy is well know for his good work and he had it done in 2 days.
